Q1 - Can I edit my audio track using a spline and points? I used the point tool and zoomed in on the waveform and then moved some points about. When I zoomed out and played it all it did was make a "Pop" sound because the area I edited was tiny in relation to the whole audio track, so how can I edit or create my own audio track by drawing waveforms? I want to change the audio so it is uniquely my own sound but I don't have a keyboard. Is this possible? Is there software out there to do this or can Audacity do this?
Q2 - How do I lengthen or shorten a sound.
Q3 - My animation is 7.28 seconds long and my audio track is 12 seconds long. What is the best way to shorten the audio track to 7.28 seconds. Is it best to compress it? Can this be done? or can I chop some out of the middle so it still sounds OK? Please explain both methods and what method you would use.
Thanks for helping this Newbie!
to position the new clip.
to create fade-in and fade-out for each clip so that they blend nicely from one to the other.
