Problems recording
generalgeorge
Re: Problems recording
Post by generalgeorge » Fri Jun 11, 2010 10:47 am
Hi there ill have to get assistance re "post" not too hot on the pc.....ill try again....,firstly.. The window in the "Mixer tollbar issues" is not the same as Mine(the exception is the microphone)and i show only 2pictures!....
When i click on "Recording"there is a picture of a Microphone...which is highlighted...and underneath greyed out it says..SIgmatel High Definition Audio Codec...then , not plugged in !
Below the microphone there is a picture of a speaker which is highlighted , and greyed out is Usb audio device !..
WHen i highlight and right clickthe Microphone picture..a similar box appears as in the "Mixer toolbar issues" which is as follows:
HIghlighted..is DISABLE....SHOW DISABLE DEVICES...SHOW DISCONNECTED DEVICES...AND PROPERTIES.
Greyed out are ..SET AS DEFAULT DEVICES AND SET AS DEFAULT COMMUNICATION DEVICES.
When i highlight and right click on the speaker picture..the following are highlighted....CONFIGURE SPEECH RECOGNITION.....DISABLE...SHOW DISABLE DEVICES...SHOW DISCONNECTED DEVICES AND PROPERTIES...HOPE THIS IS A LITTLE CLEARER .
ARMAND
Post by steve » Fri Jun 11, 2010 12:01 pm
Here's how to make a screenshot (screen capture) http://graphicssoft.about.com/cs/genera ... enshot.htm
To post the image into your forum post, click on the "Upload Attachment" tab below the "compose message" box. Click the Browse button and find the screenshot image on your computer, then press the "Add the File" button. Then click the "Place inline" button.
generalgeorge
Post by generalgeorge » Sat Jun 12, 2010 1:49 pm
Hi i will have to ask for assistance here .i looked at the site you gave and.. held down the alt key and print screen , on the window (show devices etc)i was hoping to send but ..nothing happened .....as i said an old head is struggling.....ill get back asap...
generalgeorge
Post by generalgeorge » Wed Jun 23, 2010 7:34 am
Hi sorry about all the inconvenience ,however i purchased a uca-202 interface , it resolved most of the issues..however ,how when i am transfering from a digital recorder my own music..to enable to show each individual track so that i can adjust the highs and lows of the music...its probably simple but and old head takes time.....
Post by steve » Wed Jun 23, 2010 5:02 pm
generalgeorge wrote:i purchased a uca-202 interface , it resolved most of the issues..
Great :D
There is a tutorial here (Splitting recordings into separate tracks) that covers the relevant procedures - the relevant part is where it talks about setting labels to mark the start of songs. The examples shown are using Audacity 1.2.6 and will look slightly different with 1.3.12, but the procedure is basically the same.
