Install error: NTVDM CPU contains non-valid instruction
jazvec
Post by jazvec » Tue Feb 19, 2008 7:53 am
Hi,
I was trying install Audacity, but I did not successfull. The reason is error: "NTVDM CPU contains non-valid instruction". I tried all available version of Audacity on my Acer Aspire 1350LC with Athlon XP-M CPU (win xp home), and on desktop with Intel Dual-Core E2180 (vista home premium). The result was the same. But I found an older version (1.3beta) with runs well. Where is the problem ? I attached the image with error message.
Thanks,
MJ
ubiquitous
Re: Install error: NTVDM CPU contains non-valid instruction
Post by ubiquitous » Tue Apr 08, 2008 4:05 am
Same problem, error says: "The NTVDM CPU has encountered an illegal instruction. CS:11d9 IP:02bf OP:63 6f 6e 74 65 chose 'Close'......"
any solution?
can post any necessary system specs if needed
