TEMPORARYTOPWINDOW
musicmaker
TEMPORARYTOPWINDOW
Post by musicmaker » Thu Aug 02, 2007 4:55 am
Yeah, my problem is when I try to launch the program. A window appears and says TEMPORARYTOPWINDOW. What can I do? What is the problem? What should I do?
Thanks for your help.
By the way, I'm new here and Hello everybody.
God Bless you all
richardash1981
Re: TEMPORARYTOPWINDOW
Post by richardash1981 » Thu Aug 02, 2007 12:25 pm
The window is normal, but should immediately disappear again as audacity starts, so you normally never see it. So the real problem is that audacity won't load. What version of audacity are you running, and what version of windows?
tyler tyler
Post by tyler tyler » Sun Aug 19, 2007 8:05 pm
im having the same problem, when i try to open audacity or any file i have saved in it, it opens a window that says temporarytopwindow, then it dissapears with no audacity. i am running version 1.2.6. on windows xp. can anyone help?
j2n
Post by j2n » Mon Sep 10, 2007 8:13 pm
I too am having this problem. Audacity was working perfectly fine about ten minutes before I installed the VST Enabler. I'm going to uninstall the whole thing and try reinstalling.
dazza101
Post by dazza101 » Tue Nov 13, 2007 1:35 am
I am also having this problem - audacity (v1.2.6). It was working fine a few days ago, and now all I get is the Temporarytopwindow - which just hangs and the program never loads. I have tried uninstalling and reinstalling v1.2.6, but I am still getting the same problem. Any suggestions?
dazza101
Post by dazza101 » Wed Nov 14, 2007 4:28 am
Okay, I have deleted the Audacity folder, scrubbed the registry, and reinstalled the software after a reboot - it hasn't solved the problem. Audacity refuses to run at all - I still just get the temporarytopwindow - which just hangs and is not using any system resources at all. Audacity v1.2.6 and AMD 4200 X2 processor, 2 GB ram, Win XP SP2 with latest updates. Any help would be be really appreciated!
