mon-b wrote:HI!
I don't know why but audacity doesn't show VST effects in the effect list...
I tried to install the Autotune Evo VST, it says that's correctly installed but I can't see it!!
Please tell me if i did something wrong:
-I installed the vst bridge into the audacity plugins folder
-I put the Autotune folder into the VST Enabler one
Where do I have to put the Autotune DLL file to make it work?? I put it with the other plugins already in audacity and with the vst bridge....
It would be better if you posted in the Forum for your particular operating system and version of Audacity.
You have to put the dll for each VST plug-in in the Audacity Plug-Ins folder, or in the other
specific locations where Audacity looks for VST plug-ins. You then have to restart Audacity.
I very much doubt Autotune will work with Audacity 1.2. Download the
latest 1.3 Beta version. That does not need the VST Enabler and will display VST plug-ins with full interface instead of just as a table with boxes and sliders. 1.3 should detect existing VST plug-ins the first time you run it. If you add new VST plug-ins after that, you have to set a rescan in the Effects Preferences and restart Audacity.
If you want a free pitch correction plug-in for Windows, you can try
GSnap.
