iMic Not Recording Clear
I recently bought the iMic to record some dj mixes and for some reason when I record with audacity it doesnt sound very clear. It sounds very muffled and as if it wasnt loud enough. The mixer is turned up to the right levels and I'm using OSX Tiger on my ibook G4, when I was using leopard on a macbook pro with audacity also to record it was sounding fine. Any clue on this!? Thanks ahead!
Re: iMic Not Recording Clear
I'm personally a fan of plugging your mixer directly into the Line-In of your iBook and put the iMic out in the garage where I put mine.
