Update playhead location
soundgeek2496
Is there anyway to have the playhead not return back to the selected location in which it first started? For example, I start playback at the beginning of the file and then stop playback 20 seconds later. I would like to then continue playback again, but from that 20 second mark I stopped at, and then onward; not from the beginning again as it's currently doing.
waxcylinder
Re: Update playhead location
Use Shift+A - this will stop the playback and leave the cursor at the current playback position.
