export help
biferi
export help
Post by biferi » Tue May 18, 2010 7:06 pm
Can I export a File to WMA Windows Media Audio from Audacity??
I know when I make a sound file in Audacity I can export to wav mp3 and so on but I did not see windows audio??
Re: export help
Post by steve » Tue May 18, 2010 11:15 pm
You can with Audacity 1.3.12, but you need to also install FFMpeg.
See here: http://manual.audacityteam.org/index.ph ... tallffmpeg
biferi
Re: export help
Post by biferi » Wed May 19, 2010 5:58 pm
Thanks for the help but one thing.
I un installed the old verson of Audacity and then re started the computer.
Then installed the new verson and the FFmpeg and restarted the computer.
No I go to start Programs list and can't see Audacity.
WHY???????????????????????????????????
Re: export help
Post by steve » Wed May 19, 2010 6:51 pm
You've not said which version of Windows you are using, but I suspect it is because you did not install it as an Administrator.
If you still have no joy, just make a Desktop shortcut to the "audacity.exe" file that is in the Audacity folder in the "Program Files" folder.
