Can anyone name this sound/voice effect?
axforts
Post by axforts » Wed May 12, 2010 11:46 pm
Hey everyone, trying to figure out what sound/voice effect is used here, and maybe even where I could find a way to reproduce this effect with a custom voice recording of my own(preferably free or cheaply)
Thanks everyone, heres the sample clip. No download required
http://myspacefilehosting.com/lmjyz/sample2.wav.html
Oh forgot, Im on a Mac if that makes a difference.
Trebor
Re: Can anyone name this sound/voice effect?
Post by Trebor » Thu May 13, 2010 12:03 am
A 192KHz sample rate is excessive and a huge waste of memory and download time, 44.1KHz will capture all the audio on your sample(2)...
sample2.mp3
(84.38 KiB) Downloaded 319 times
Screaming bee have software (£$) which does something similar ...
http://www.screamingbee.com/SoundClips/LichGuy.mp3
http://www.screamingbee.com/soundclips/Demon.mp3
Although a similar effect can be done from scratch by applying multiple effects ... http://forum.audacityteam.org/viewtopic ... 051#p81051
axforts
Post by axforts » Thu May 13, 2010 2:38 am
hey thanks for the reply
looks like the screamingbee software is only available for windows :/
how would one/what effects would someone use to do what you suggested with adding and layering multiple effects to obtain that result? and can it be done with just audacity?
Trebor
Post by Trebor » Thu May 13, 2010 3:40 am
axforts wrote:how would one/what effects would someone use to do what you suggested with adding and layering multiple effects to obtain that result? and can it be done with just audacity?
For a demon type voice …
Drop pitch by 15%, (i.e. -15%),
(Optional : slow speed by 5%)
Bassboost 150Hz by 10db
Delay: delay time 0.05 sec, 5 echoes, 5db decay amount .
“Change Pitch” , “Change Speed” ,“Bassboost” and “Decay” are all on Audacity’s “Effects” menu.
Your "sample2" sounds like all of the above plus vocoding with high-pass filtered noise then reverbed,
("Vocoder" is near the bottom of Audacity "Effects" menu).
normal - bleep - demon - bleep - demon vocoded with noise - bleep - then reverbed.mp3
(825.51 KiB) Downloaded 194 times
axforts
Post by axforts » Sun May 16, 2010 10:06 pm
hey thanks so much for the replies, ive managed to do those first four you suggested, am having difficulty with the vocoding, filtered noise, and reverb. my reverb effect is gverb. unsure what settings get this voice to sound abit more like the sample2. im trying to use this voice for a ghostly school project voice over, ideally id like it to layer the original voice similar to the original sample, although im sure thats as simple as laying the new track over the original and maybe a half a second behind it.
oh also, i noticed what you said in the other thread about reversing then doing the reverb then re-reversing. where would i implement the reverse and the unreverse in this particular series of steps to achieve the similar voice?
thanks again for all your suggestions.
Trebor
Post by Trebor » Mon May 17, 2010 12:57 am
In your “sample 2” the child’s voice and the demonic derivative are synchronised , definitely not “half a second behind it”.
If you must have the demonic voice lagging behind, not more than 0.05 seconds would be my suggestion, otherwise the mixture will be incomprehensible.
If you want to play the original and demonic tracks together omit the step 2 above : the optional 5% slowdown.
“Reverse” is in the Audacity “Effects” Menu.,it flips the track back to front : like playing a vinyl record (ask your parents :) ) backwards.
To create the reverse reverb effect, reverse the track, apply reverb, then reverse it back the right way round. There is no “unreverse” just reverse the reversed.
Gverb produces a horrible metallic sound and does not lend itself to the reverse reverb technique.
This ANWIDA reverb effect is very good and free.
I’ve found a way of improving the Demon voice. Make a copy of the Demon voice you’ve made using the above instructions to run simultaneously with the first. Then apply the equalization on this graph to the copy.
Equalization to boost high frequency on demon voice.png (20.51 KiB) Viewed 4647 times
The resulting mixture then has plenty of high frequency content and sounds a lot better: clearer & scarier . A before after example is attached …
[Applying plenty of reverb only to the copy track with the high frequency content produces an ethereal effect]
original - demon - demon+HighFreqBoost - reverse reveb with ANWIDA (free) reverb.mp3
(696.33 KiB) Downloaded 168 times
Post by steve » Mon May 17, 2010 1:24 am
Here's a demon voice made using Pitch Change, and GVerb (and a touch of Equalizer)
demon.mp3
demon voice
(164.03 KiB) Downloaded 240 times
Trebor
Post by Trebor » Mon May 17, 2010 1:40 am
Can you tell us what settings you used on Gverb to achieve that reverb Steve ?
[every time I've attepted to use Gverb the results have been horriby metallic]
Post by steve » Mon May 17, 2010 1:48 am
If you use much "Early Reflection" you need to keep the room size quite big.
For smaller room size, reduce the "Early Reflection" a lot.
I always use GVerb on a copy of the track then mix the original (dry) signal with the duplicate track with reverb (wet).
Trebor
Post by Trebor » Mon May 17, 2010 4:52 pm
stevethefiddle wrote:For smaller room size, reduce the "Early Reflection" a lot.
OK I’ve reduced the early reflection on Gverb to minimum (-70db) ,
and applied Gverb with the settings shown below to the high frequency copy of the demon voice.
GVerb settings applied to high frequency copy of demon.png (8.49 KiB) Viewed 4631 times
Reverb was applied normally and reverse with the same Gverb settings, result attached …
GVerb Vs ANWIDA.mp3
(517.55 KiB) Downloaded 361 times
I still think the ANWIDA reverb sounds much better than Gverb:
1) less harsh, 2) the reverb from one channel crosses over to the other giving a more realistic reverberation.
