noise remove
cpalit
noise remove
Post by cpalit » Sat May 08, 2010 12:40 pm
I have recorded a music track from a concert hall. After importing it into Audacity,how will I remove the unwanted voices and clappings that has also been recorded along the track?
Trebor
Re: noise remove
Post by Trebor » Sat May 08, 2010 2:07 pm
If your show is people talking and the "noise" is people talking in the background, That's not noise. All those people are performers and you can't separate them.
http://forum.audacityteam.org/viewtopic ... 858#p83858
whomper
Probationer
Re: noise remove
Post by whomper » Sat May 08, 2010 5:50 pm
if its between the music you can use the cut or silence function.
if during the music, you really can't do anything meaningful to fix it.
