Hey i used to have a windows XP Computer, and i was able to record the sounds my computer makes, by changing the item which recorded the sound from microphone to stereo mix, I've rescently purchased my self a vista pc, and i've had to download the 1.3.3 version(BETA) And i cant find that feature.
Is this feature on this version? If so where?
Thanks.
Tim.
I need to record Stereo MIX (Sounds which my pc makes)
Re: I need to record Stereo MIX (Sounds which my pc makes)
Don't cross post. I'm deleting your other topic.
The answer you your question can be found here:
http://audacityteam.org/forum/viewtopic ... 7216#p7216
