Audio output converted to time & signal?
Storer
Re: Audio output converted to time & signal?
Post by Storer » Thu May 06, 2010 3:47 pm
Jake,
To help Steve with the plug-in problem, click on the Debug button instead of the OK button. When do this, you will still set the "Did not return audio" message, but when you click OK to dismiss that info box, another debug box will appear with a lot of incomprehensible text. Cut all the text, top to bottom, and paste it into a message to StevetheFiddle. It will help him figure out what is wrong. Since it's a small plug-in, I may be able to spot the problem it you PM the debug text to me also.
It's probably a typo of some sort.
Dave
Post by steve » Thu May 06, 2010 9:53 pm
It's for mono tracks only.
