Bitrate
This section is now closed
ukpup
Bitrate
Post by ukpup » Mon Feb 04, 2008 7:34 pm
I've been trying to figure out how to reduce the size of the MP3's I exporting. the Source audio is 128 and I'd like to export it as at 64 just to get the size down. I have gone into Prefs > File Formats > Bit Rate and set it to 64. However, when exporting it is still 128, so I'm guessing that bit rate is not for exporting.
Is there a way to cut the Bit Rate when exporting?
Thanks.
Re: Bitrate
Post by kozikowski » Mon Feb 04, 2008 9:37 pm
You need to restart Audacity for some settings to take affect.
