Trouble X-ferrg tapes to Audacity
Rickenbacker
Post by Rickenbacker » Mon Apr 26, 2010 7:57 pm
I know how to set it all up to do the actual recordings, but the trouble I'm having is after I get the audio into Audacity.
The recordings are of live shows & are all roughly 90 - 120 mins. long. By the time I'm done, playback via Audacity is sooo choppy& I give up.
What can be my problem here? Thanks for any help!
Re: Trouble X-ferrg tapes to Audacity
Post by kozikowski » Mon Apr 26, 2010 8:03 pm
Choppy is usually the computer not being able to keep up. How full is your hard drive and have you ever defragmented it?
Defrag
-- Right Click Start > Explore > Right Click Local Drive C: > Properties (Used, Remaining)
-- Tools > Error Checking & Defragmentation
Never let the drive get over 90% full. Some use less, like 80%. At 90%, you're already in doo-doo (technical term).
Which Windows?
Rickenbacker
Post by Rickenbacker » Mon Apr 26, 2010 8:20 pm
Thanks for the speedy reply, Koz. I realized that I'd been running it via my external HD. Not my laptop's. (which has 32.5 GB free space vs. the external's 6.32)
I'll give it try thru the laptop & see how it goes & return if I have further problems...
