How to make sound muffled?
Ruriko
Post by Ruriko » Sat Apr 24, 2010 1:45 am
I have a missile sound effect that's flying all over the place and I was wondering how can I make it sound muffled when it flies around a large rock cliff?
flying.mp3
(42.45 KiB) Downloaded 723 times
Re: How to make sound muffled?
Post by kozikowski » Sat Apr 24, 2010 2:27 am
This sounds like one of our television commercial clients. "You have to pull off a complex special effect and you have two seconds, Have a good time."
Any way to get maybe five or six seconds of base sound?
Post by steve » Sat Apr 24, 2010 11:33 am
Make a copy of the track (select the track, then Ctrl+D)
Apply the "low-pass filter" (Effect menu)
Try the default settings in the low-pass filter first. To make it more muffled, increase the "Rolloff" setting or lower the "Cutoff frequency" (leave the filter quality at 0.7071).
Then use the fade-in and fade-out effects to cross fade from the original track to the filtered copy.
