No waveform appears in Audacity window
This section is now closed
pek
Post by pek » Sat Feb 02, 2008 7:27 pm
I just installed Audacity v1.2.5 following (checking and rechecking) all the instructions. I have my Ion iTTUSB turntable connected to my Intel-chip iMac (OS10.4.11). The record I'm trying to record into the computer plays through the iMac and the meters are working, but no waveform appears in the Audacity window. (Yes, the toolbars are all checked in the Interface window.) Therefore, I am stuck, and help will be appreciated.
Re: No waveform appears in Audacity window
Post by kozikowski » Sun Feb 03, 2008 12:35 am
First thing, shut down the Mac, disconnect the USB turntable and restart. Leave the turntable off. When everything is working again, go into the Mac System Preferences and make sure the built-in microphone is selected as the input and the little lights flash when you talk.
Close the panel. Open Audacity, select Default Input as the audio source and try to make a short recording with you talking. Make sure the level control is all the way up. Did that work? Do you get the jumping red lights and a waveform on the timeline? Forget the turntable until we get the basic sound services working.
DavidG
Post by DavidG » Sun Feb 03, 2008 8:17 am
kozikowski wrote:First thing, shut down the Mac, disconnect the USB turntable and restart. Leave the turntable off. When everything is working again, go into the Mac System Preferences and make sure the built-in microphone is selected as the input and the little lights flash when you talk.
I am experiencing the same problem. I can make a recording through built in sound input, and through iMic USB headset, monitor the input, and play it back; but no waveform is shown.
iMac G5, OSX 10.4.11
pek
Post by pek » Sun Feb 03, 2008 9:46 pm
Koz & David G.Thanks for the help. I followed the advice and also played around some with my technique and got the waveform to work and even ripped and burned my first CD. PEK
Post by kozikowski » Mon Feb 04, 2008 12:03 am
Wait a minute. You make a recording and you don't get a screen that looks like this?
http://kozco.com/audacity/audacityPanel.jpg
Or you get that screen but the blue lines are straight instead of thick and wiggly?
DavidG
Post by DavidG » Mon Feb 04, 2008 9:54 am
kozikowski wrote:Wait a minute. You make a recording and you don't get a screen that looks like this?
Koz,
Precisely that, screen but no waveform - straight blue lines..
DavidG
Post by kozikowski » Mon Feb 04, 2008 5:33 pm
When you make a recording, do the bouncing red lights on the upper right consistently stay below 36? Audio below 36, besides being way too low, will not show up on the waveform.
DavidG
Post by DavidG » Wed Feb 06, 2008 5:06 pm
kozikowski wrote:When you make a recording, do the bouncing red lights on the upper right consistently stay below 36? Audio below 36, besides being way too low, will not show up on the waveform.
Koz,
Sound input as monitored, usually around the -12 mark. But still nothing in the waveform window. BTW, I've installed Audacity 1.2.6 now in Leopard 10.5.1 - same problem as in Tiger. I assume by bouncing red lights, you mean the red strip indicator in the Meter Toolbar?
DavidG.
