trouble with export mutiple
WMG
Post by WMG » Fri Feb 01, 2008 10:19 pm
I have been working with Audacity for a couple weeks and doing export mutiple with no trouble until today. Now when I try this it adds the name of the first label with .wav after it and says it can not export to this location. I can save the audacity file and save a single WAV file with no problem. I have tried to save to various folders, but it always adds the label and .wav at the end. The actual message comes up as ( Cannot export audio to C:Documents and SettingsMy NameMy DocumentsMy MusicScarlatti cantata "o Di Betlemme altera".wav ) I would appreciate any help.
Re: trouble with export mutiple
Post by kozikowski » Sat Feb 02, 2008 7:33 am
<<<it can not export to this location.>>>
Just to cover the bases, is your hard drive starting to fill up? If you've been doing audio production for weeks without cleaning out some files, it may be getting a little cozy on the hard drive.
One other idea, did you try to use any punctuation marks in your filenames? One sure way to commit digital suicide is to put either slash mark ( / ) in a filename.
WMG
Post by WMG » Sat Feb 02, 2008 3:53 pm
Hi KOZ
I did have quote marks in the label name. When I removed these the files exported with no problem. Thank you so much for your help. Now back to more records.
