Re: Problems recording.
Post by steve » Sun Apr 18, 2010 5:56 pm
bugmenot1 wrote:I can't uncheck "software play through", because I need to hear the song.
"Overdub" needs to be selected but not "Software Playthrough".
You should be able to uncheck "software playthrough" and still hear the song.
Post by steve » Mon Apr 19, 2010 5:58 pm
Oh dear - I've no idea why either :?
What do you mean "garbled"?
Post by steve » Mon Apr 19, 2010 10:32 pm
And the bottom of the Transport menu looks like this?
transport menu
whomper
Probationer
Post by whomper » Tue Apr 20, 2010 12:24 am
stevethefiddle wrote:Oh dear - I've no idea why either :?
what is the sound card. what options are set in the sound card?
Post by steve » Tue Apr 20, 2010 9:05 pm
bugmenot1 wrote:Is there anyway I could mute just one track while recording?
Yes, you can use the "Mute" button on the left side of the track. Alternatively you can use the "Solo" button which will mute all other tracks except for those with the solo button pressed.
However, to get to the bottom of this I'd like to know what this "garbled" effect is that you are getting. Would you be able to upload a short sample of a recording to the Internet (for example to "sendspace.com") and post the download link in your reply. You will need to make a short recording, then use "File menu > Export" to create an audio file that you can then upload. Preferably you should export it as a WAV file. The recording only needs to be a couple of seconds long. If you could include as much detail as possible about how you made the recording (what equipment, how it's connected up, what settings you are using, what buttons you press, etc) that could also prove useful.
Post by steve » Tue Apr 20, 2010 10:06 pm
bugmenot1 wrote:when I play back the recording, it is no longer in sync with the song. Why would this be?
The "latency correction" is not set up correctly.
See here for how to adjust it correctly: http://manual.audacityteam.org/index.ph ... tency_Test
Post by kozikowski » Tue Apr 20, 2010 11:12 pm
<<<That's the uncompressed .aup zipped>>>
Did you include the _data folder? The AUP isn't a sound file. To get a sound file you have to Export one.
Post by steve » Tue Apr 20, 2010 11:35 pm
kozikowski wrote:Did you include the _data folder?
Surprise Koz - AUP and _data folder included, both within the same (zip'd) folder. Is this the first time we've had a working Audacity Project posted?
bugmenot1 wrote:I've tried that and I can't seem to get it right for some reason.
Yes, that's a long way out isn't it.
What settings do you have in "Edit > Preferences > Recording" for "Audio to buffer" and for "latency correction"?
(take care to specify if the numbers that you have entered are positive or negative - or just post a screen shot).
Post by steve » Wed Apr 21, 2010 4:08 pm
Assuming that those are the same settings as when you made the latency test recording -
Set the "Latency Correction" to -228 (that's "minus" 228)
Then run the latency test again - hopefully it will be somewhere close.
Post by steve » Wed Apr 21, 2010 11:23 pm
Well it's fixed the latency adjustment :)
So was that after only changing the "latency correction" setting?
If you change it back to 0 does it still produce the same result as the first "Click" project?
