Slowing a sample down...
TheKLF99
Post by TheKLF99 » Wed Apr 14, 2010 9:34 am
Hi,
I've heard on a few songs where they do a really good effect of slowing a sample right down, usually in the middle of the song, but it isn't actually slowed down as the pitch doesn't change.
Like on Up Tha Wildstyle by DJ Supreme and The {word rejected} Kings - where there is a sample that goes "D....J.....Suuppppremmmee and the porrrrnnn kinnnngs"
Also Rock FM in Preston use this effect when they play their jingles on Saturday Night.
Is there a plugin for Audacity that allows this effect, or does anyone know what this effect is called, as I've tried looking at slowing the sample down, but that doesn't sound right as the voices then go way too low.
Trebor
Post by Trebor » Wed Apr 14, 2010 10:47 am
TheKLF99 wrote:... does anyone know what this effect is called
http://en.wikipedia.org/wiki/Audio_time_stretching
Audacity 1.3.11 has "slding time scale" which can slow down a track without altering pitch ...
Before-After sliding time scale (Audacity 1-3-11).mp3
(173.06 KiB) Downloaded 138 times
[ Very Troy McClure :) ]
TheKLF99
Re: Slowing a sample down...
Post by TheKLF99 » Wed Apr 14, 2010 11:53 am
Thanks for the help, found out that it's the Tempo I need to adjust not the speed/pitch and it works perfect :).
