LP recording
parts308
LP recording
Post by parts308 » Mon Apr 12, 2010 6:09 pm
I recorded an entire LP, both sides. How can I seperate the recorded LP into single songs?
Bill
whomper
Probationer
Re: LP recording
Post by whomper » Mon Apr 12, 2010 7:25 pm
look at the waveform. db view is by far the easiest to use.
find the start of each song. the waveform from an LP should have a couple of seconds of low level between songs which makes it easier to find.
use the magnify on the left of the track to help. looking at about 5 minute segments may help too (magnify on the track itself to get it to show about that length)
put the cursor before the start of each of the next cuts on the LP and do a ctrl-B. don't forget to do it before the very first one too!
when you export you will have separate wav files for each song to burn to a cd.
Re: LP recording
Post by steve » Mon Apr 12, 2010 10:15 pm
parts308 wrote:I recorded an entire LP, both sides. How can I seperate the recorded LP into single songs?
Bill
Hi Bill,
there's a tutorial for that here: http://wiki.audacityteam.org/wiki/Split ... ate_tracks
Steve
waxcylinder
Re: LP recording
Post by waxcylinder » Tue Apr 13, 2010 10:15 am
And this is a similar tutorial from the manual that is under development for 1.3/2.0: http://manual.audacityteam.org/index.ph ... ate_tracks
You may find the other tutorials in this set in the manual useful too: http://manual.audacityteam.org/index.ph ... iscs_to_CD
parts308
Re: LP recording
Post by parts308 » Wed Apr 14, 2010 2:07 pm
Thanks for the assistance guyz
