files&folder
dreeser
files&folder
Post by dreeser » Mon Apr 12, 2010 5:08 pm
when i went to open my saved project,an error box came up.couldn't
find the project data folder.i clicked OK. then it said,could not
load file.in Audacity i went to file,then open.i Sean it in there,
highlighted it,typed in the name for the find it box,clicked OK.
same error box came up.could you tell what I;m missing.
thanks so much
Re: files&folder
Post by kozikowski » Mon Apr 12, 2010 5:46 pm
The AUP project manager file (it's not a sound file) and the _DATA folder need to be in the same place. If you have one in one folder and the other somewhere else, the show is never going to open.
It's scary that this is happening because the next thing you're going to complain about is pieces of your show are missing. That happens, too, when you start moving files around.
whomper
Probationer
Re: files&folder
Post by whomper » Mon Apr 12, 2010 7:29 pm
kozikowski wrote:The AUP project manager file (it's not a sound file) and the _DATA folder need to be in the same place. If you have one in one folder and the other somewhere else, the show is never going to open.
well ... actually if you go into the aup folder and edit the location of the data folder it works fine.
Re: files&folder
Post by steve » Mon Apr 12, 2010 10:31 pm
whomper wrote:well ... actually if you go into the aup folder and edit the location of the data folder it works fine.
I presume you mean - edit the .aup file.
Doing that can be risky. All but the most simple projects have multiple directory references and you must get every one exactly correct or the project will be broken. The task may be complicated further if there are dependencies.
It is very much better to just get into the habit of not moving, deleting, renaming, or changing any files or folders that are involved in a project until you have finished with the project and exported the completed audio file.
whomper
Probationer
Re: files&folder
Post by whomper » Mon Apr 12, 2010 11:42 pm
good point
i moved all the files once. and got it to work by editing where i found the path in the aup folder (which i suppose was in the aup file )
now i have all the paths set to where i want them so no more monkeying around like this.
Re: files&folder
Post by kozikowski » Tue Apr 13, 2010 3:41 am
<<<now i have all the paths set to where i want them so no more monkeying around like this.>>>
The problem is trying to explain that to somebody who only has a very shaky notion how their computer works. Much better and more simple: You can't move an Audacity Project and if you did, put it back.
