Recording levels too low?
Been using audacity for years.. but got a new computer and am setting it up for the first time on this machine.
I'm having a really hard time getting a decent recording level in Audacity. On my sound card monitor (m-audio delta AP), I'm registering at around -10 db with peaks at -2 or so (which is what I want).. but the best I can get in a recording on Audacity is around -36 db.
Any thoughts?
FYI: I'm running a mic into a mixer, into a compressor/limiter, into a sound card. Running windows xp. Voice recording only.
Any thoughts?
Re: Recording levels too low?
Your sound card driver has probably got a mixer or control panel, most likely with an icon for it in the sys tray (near the clock). You will probably need to adjust the recording volume in there.
Thanks Steve. As mentioned, the levels in my sound card mixer are registering at -10 with peaks of -2db... so sound is coming in to the computer just fine. It's just not recording that way.....?
I'm talking about a software mixer application - it will have separate settings for record and playback. The fact that you can hear it just says that the playback level is ok, but if the record level is too low then it will record very quietly.
How high is it metering in Audacity while you record?
<<<How high is it metering in Audacity while you record?>>>
It's good to know that you can launch Audacity and click once inside the red record meters and they will become active whether or not you're actually making a recording. This is terrific for testing since the meters will show you what you're doing as you make the adjustments.
To clarify:
On my sound card software, the mic level (ie., input meter) is registering at -10 db.
On Audacity, the record meter is barely getting past -36 db.
My question is.. do I have a setting wrong somewhere?!
Can you recommend a software mixer application?stevethefiddle wrote:I'm talking about a software mixer application
You gotta dig around in your Windows Sound Panel.
All the devices and destinations in your machine have two (or more) pathways. There is a pathway that goes from your sound device (microphone?) through the sound card and up to your headphone or speakers. There is a completely separate pathway that goes from your microphone through the sound card and into Audacity. This is one of the things that makes dealing with Windows so darn much fun.
You just haven't found the right level control yet. In older Windows, where they hadn't figured out a way to hid it all yet, you actually had two completely different plain-looking sound panels and you could adjust them to suit your work. The newer Windows have a one, pretty, colorful panel that nobody knows how to work.
Hah! Figured it out, and it had nothing to do with the control panel or audacity.
On a lark, I decided to try an older driver for the sound card, as that was one of the only things different from the old computer to the new one.
Works like a charm now.
Thanks for your help.
waxcylinder
Interesting.....
bearing in mind that the usual advice is to upgrade your soundcard drivers - vaiza shows that regression can sometimes work .....
