how to merge two or more tracks into one?
Re: how to merge two or more tracks into one?
Thanks for the links wax, but for some reason the 6th pulldown menu (Create) commands doesnt seem to be covered. For example Create Silence, which I'd like to make key binding for. How do I do that?
Unfortunately that is not yet implemented. It is in the "highest rated" section of the "Feature Request" page on the Audacity wiki.jonasjar wrote:Create Silence, which I'd like to make key binding for. How do I do that?
http://wiki.audacityteam.org/wiki/Feature_Requests* Bind effect parameters to buttons or keyboard shortcuts: including particular settings thereof e.g. one keystroke to amplify + 3 dB, another keystroke -3 dB, another to compress (25 votes)
o Effects for which this has been requested: Amplify; Change Speed; Fade In/Out; Generate Tone; Insert Silence; Noise Removal; Repair; DC removal ; Chris' Compressor
Would you like me to add your vote?
