Seperating tracks
dama7
Seperating tracks
Post by dama7 » Thu Apr 01, 2010 8:24 pm
I know you can seperate tracks by clicking CTRL+M while recording, or CTRL+B while editing. No mater how much "clicking" I do, I can't get the label (flag) to slide up or down the timeline if I need to move it. It has to be simple, but I don't get it. BTW, will placing the label between tracks create seperate tracks when, after saving the project, they're transfered from the PC to a CD? Thanks for any help, I'm suffering from information overload after downloading the beta version.
Dave G.
Re: Seperating tracks
Post by kozikowski » Thu Apr 01, 2010 11:03 pm
Labels are changing probably as I type this. Labels are nice, but everybody really wants Edit Markers and Audacity won't do those. So...
http://manual.audacityteam.org/index.ph ... bel_Tracks
waxcylinder
Post by waxcylinder » Fri Apr 02, 2010 10:00 am
You really need to upgrade to 1.3 - 1.3.12 has just been released. Label handling is much improved in 1.3 (and still changings as Koz says ...)
You can get 1.3.12 from here: http://audacityteam.org/download/
whomper
Probationer
Post by whomper » Fri Apr 02, 2010 3:22 pm
dama7 wrote:...No mater how much "clicking" I do, I can't get the label (flag) to slide up or down the timeline if I need to move it. It has to be simple, but I don't get it. ...
wow! tell me how you do *that*
i can't get my labels to stay where i put them.
anything i do seems to make them move and then i have to put them back.
waxcylinder
Post by waxcylinder » Fri Apr 02, 2010 4:14 pm
Mine stay rock solid where I put 'em unless I either explicitly drag them around - or if I delete a selection from either within the label track or the audio track in which case thay move.
1.3.12 has brought back the functionality whereby if you select the same timeline chunk of audio and label tracks and then delete - the labels move to stay in synch - hooray.
dama7
Post by dama7 » Fri Apr 02, 2010 4:50 pm
OK guys, I've already downloaded 1.3.11 but still need to know how to slide the label (flag) up or down the time line between tracks. When I click on it and pull the mouse on way or the other, I just get a blue field, the label doesn't move at all.
waxcylinder
Post by waxcylinder » Fri Apr 02, 2010 4:52 pm
You want 1.3.12 not 1.3.11
Post by steve » Fri Apr 02, 2010 5:48 pm
Using Audacity 1.3.12 (not implemented in previous versions)
To create a label at the cursor position while in "STOP" mode...
cursor position.png (7.62 KiB) Viewed 732 times
Ctrl+B to create a label. Add label text if required by typing.
To move the point label, click in the centre dot (will turn white) and drag left or right.
drag label.png (10.15 KiB) Viewed 732 times
whomper
Probationer
Post by whomper » Sat Apr 03, 2010 1:51 pm
righto, but i want that dot to stay where it was to mark the start of the next cut to export.
(enable it with a right click should someone need to move it though)
can't drag the arrows unless i move the dot first
as of 1.3.9 anyway
which means i have to move the dot back to line it up
i understood i had to line the arrows up or export multiple had random problems. other than that bug they seem to provide no functionality that is worth all this effort.
do i understand correctly that in 1.3.13++ that the dots will be anchored and the arrows will expand automatically ? and the export multiple problem is gone so we dont have to mess with arrows at all?
it would make more sense to have only one arrow on the right side.
set the dot at the start of the track to export and lock it down. then drag the arrow to the end of the selection. or better just move the arrows to the next dots automatically in case of export multiple. (all tracks should have an implicit dot at the beginning and end for this to work best. )
Post by steve » Sat Apr 03, 2010 5:04 pm
whomper wrote:righto, but i want that dot to stay where it was to mark the start of the next cut to export.....
Audacity 1.3.9 is an old beta version. As already stated the behaviour of labels has been updated to improve functionality (as part of the ongoing development of Audacity.
Please use the latest version of Audacity 1.3 and If you still have questions start a new topic rather than hijacking someone else's question.
