Editing and exporting a mp3, small empy space on beginning!
brunoja
Post by brunoja » Tue Mar 23, 2010 7:53 pm
Hello!
When I edit a mp3 file and exports it, audacity creates a small empty space on the beginning of the track, I would like it to dont do that, what should I do?
Ive attached an example:
Here is the original mp3:
This is the mp3 file...
Here is the result of the export:
This is the result of the export...
Thank you!
Re: Editing and exporting a mp3, small empy space on beginni
Post by steve » Fri Mar 26, 2010 1:51 am
That is a limitation of the MP3 format - it does not exactly define the start of the audio. If you need to define the beginning of the audio exactly you need to use a different file format such as WAV, Ogg, Flac or AIFF.
