Here you go John:jhoski wrote:Steve - after step 3 can you save what you have so I can compare mine and also around step 6 or 7? Thanks again, John
Using Audacity 1.2.6 (Exported as mp3 for smaller files and quicker downloads)
Original sample: http://easyspacepro.com/audacity/testsample.mp3
or as a wav: http://easyspacepro.com/audacity/testsample.wav
1) Low pass filter 6000 Hz
http://easyspacepro.com/audacity/1.mp3
2) High pass filter 300 Hz
http://easyspacepro.com/audacity/2.mp3
5) Low pass at 600 Hz
http://easyspacepro.com/audacity/5.mp3
6) Duplicate with High pass at 600 Hz
http://easyspacepro.com/audacity/6.mp3
7) Low frequency track (from step 5) with noise removal set to min (noise sample selected from this track)
http://easyspacepro.com/audacity/7-low.mp3
10) High frequency track (from step 6) with noise removal set to min (noise sample selected from this track)
http://easyspacepro.com/audacity/10-hi.mp3
11A) Low frequency track (from step 7) with Low Pass filter at 400, then High Pass filter at 300, then amplified by 6 dB.
http://easyspacepro.com/audacity/11a.mp3
11B) High frequency track (from step 10) with High Pass filter at 1500, then Low Pass filter at 2000 Hz, then amplified by 6 dB.
http://easyspacepro.com/audacity/11b.mp3
13) 11A and 11B mixed and amplified to 0 dB (+5 dB amplification)
http://easyspacepro.com/audacity/13.mp3
14) Gate settings:
LF key: 800
HF key: 2000
Threshold: -53dB
Attack: 30ms
Hold: 600ms
Decay: 300ms
Range: -30dB
Output: 0 (gate)
http://easyspacepro.com/audacity/14.mp3
