Menus
peppeq
Menus
Post by peppeq » Thu Mar 18, 2010 1:13 pm
I installed Audacity 1.3 over MS Windows Vista updated to the last service pack and patch, but launching the program I found that a large part of menu items have a very little character (non all the menu items!), both in main and secondary menus.
I found the same problem with 1.2 version.
What is the problem? I attach a screen shot of my installation.
Plase help me!
Bye.
Peppeq
waxcylinder
Re: Menus
Post by waxcylinder » Thu Mar 18, 2010 1:33 pm
In 1.3 tochange the language use: Edit>Preferences - Edit is the second command in from top left, then Preferences is the bottom selection in the drop-down list.
Then you need the Interface tab, which is the fifth item in the list
In the dialog box there should be three wide drop-down selector boxes. The middle one enables you to select the language – select English
And then click the OK button – which should be the left-most button at the bottom right.
To change the language in 1.2.x use: Edit>Preferences - Edit is the second command in from top left, then Preferences is the bottom selection in the drop-down list.
Then you need the Interface tab, which is the third one in from the right.
Language is selected from the only drop-down list in the dialogue box - use this to change to English.
peppeq
Re: Menus
Post by peppeq » Thu Mar 18, 2010 3:37 pm
Thank you very much, the problem is solved also using italian language.
I don't know why there was the language khmer.
Bye.
Peppeq
