Error messages in audacity. can't record.
knit-tweaker
Post by knit-tweaker » Thu Mar 18, 2010 3:47 am
I just downloaded Audacity. Hooked up my Tascam 130 tape recorder to my computer via the line in. Clicked on edit, selected preferences, selected the device, it shows "modem #0 line record." I selected that. I tried to record, got message," error opening sound device. Please check the input device settings" etc. I checked my connections, all are good. What up? What can I do? I know that the program records because when I selected the internal sound module it showed it recording.
Help! I have Window XP 2000
Knit-tweaker
whomper
Probationer
Re: Error messages in audacity. can't record.
Post by whomper » Fri Mar 19, 2010 4:44 pm
knit-tweaker wrote:
Knit-tweaker
try the other device
i never use modem#0 and my recording works
knit-tweaker
Post by knit-tweaker » Sat Mar 20, 2010 5:12 am
Whooper: I am trying to record from my Tascam mix down recorder into my computer. The only devices it shows, is Sigma tel Audio, modem #0 line in, and mapper.
Knit-tweaker
Post by kozikowski » Sat Mar 20, 2010 6:16 am
You might try changing Audacity sound preferences to 44100 (probably already there) 16-bit (not 32-bit) and 2(Stereo) not 1(mono). Restart Audacity and try it again. Those are the sound standards for a Music CD and almost everybody supports them.
Post by kozikowski » Sat Mar 20, 2010 6:17 am
Oh, and do make sure your Windows Control Panels are set correctly, although if other programs work, that's not likely to be wrong.
knit-tweaker
Post by knit-tweaker » Sat Mar 20, 2010 3:15 pm
OK! I change it to 16 bit. Tried again. NO luck. Same message-"Error while opening sound device. Please check the input device settings and the project sample rate."
knit-tweaker
