piano sounds great going in, lousy in Audacity
Jim Robbins
Re: piano sounds great going in, lousy in Audacity
Post by Jim Robbins » Tue Mar 23, 2010 9:02 pm
I finally got the piano to record in stereo. However, on this track, you'll notice that the piano falls behind the rest of the track by almost a click. Is this a latency issue? How can I correct it? http://www.snapdrive.net/files/372235/S ... %20off.mp3 I'm even pushing my tempo on the piano as I record it, but it doesn't help much. Any ideas?
Post by steve » Tue Mar 23, 2010 10:31 pm
Jim Robbins wrote:FOR RECORDING KEYBOARDS FROM A MIXER using USB INTO YOUR LAPTOP: (if using Windows Vista)
Well it's actually for recording anything that's Line level via USB in Vista, but thanks, that's very clear.
Jim Robbins wrote:on this track, you'll notice that the piano falls behind the rest of the track by almost a click. Is this a latency issue?
No, I don't think so - in fact I don't think that it has anything to do with the "recording". The "timing" is fluctuating quite noticeably, but there is no fluctuation in the "pitch" of the piano. If the recording speed was varying enough to cause such variation in the timing I think there would be noticeable "wow" in the pitch (much like playing a warped vinyl record or a stretched cassette tape), but that is not happening. It sounds more like the piano is just playing at the wrong (and inconsistent) speed.
This music is "sequenced" in some way? Perhaps you can describe what you are doing - how the parts are played and how you are putting them together.
Jim Robbins
Post by Jim Robbins » Wed Mar 24, 2010 1:34 am
Thanks, Steve. I had already recorded the rhythm track and synth track. I've now been trying to play the piano line over the top. I'm using the "overdub" playthrough function. I don't know if it's just that I'm not used to playing against an exact rhythm track (vs a 'live' drummer) or not. In my head, as I'm recording the piano over the other tracks, it feels like I'm in sync with the other tracks. I'm even pushing my tempo a bit, (not consistently, I guess) in order to make sure I'm playing in sync. That gets a little frustrating -- concentrating on not getting out of sync rather than allowing musicality.
I thought that maybe there's a very slight delay happening somewhere as I'm recording the piano. Or...it could be just me not used to playing in metronomic exactness. ;)
Post by steve » Wed Mar 24, 2010 10:05 pm
The trouble with playing against a metronome is that metronomes never keep time :D (or at least it seems like that).
It is a task that is much harder than most folk would imagine, until they try to do it.
There WILL be a delay between you playing a note and it being "written" to the hard drive (latency) but that should not be a problem. The important thing is that you have your equipment set up so that you can hear the piano sound immediately (without any delay) and that you play in sync with the rhythm track that is playing in Audacity. If you fulfil both of those conditions then even though there is "latency" that puts the new piano track slightly later than the rhythm track it will be "out" by an equal amount throughout the track and can be adjusted automatically with "latency correction", or by dragging the track a little way with the Time Shift tool. The hard bit is playing in time with the "metronome".
Jim Robbins
Post by Jim Robbins » Wed Mar 24, 2010 10:52 pm
Hi Steve,
I tried the latency correction test. http://manual.audacityteam.org/index.ph ... tency_Test
I followed the directions exactly -- even did it twice -- but the latency correction didn't take effect.
I figured out the latency, entered the correction amt in the "Recording" preferences, and re-recorded the click-track with latency correction -- but it didn't change at all. It didn't correct for latency. (.180)
Any ideas? Is it different for the Beta version of Audacity?
When I record the piano on top of the other tracks. I'm using headphones through the headphone jack in the USB mixer. I can hear the rhythm track fine as I play piano overdubs.
Post by kozikowski » Wed Mar 24, 2010 11:24 pm
There are three delay problems in audio production. Latency is adjusted using the tools provided in Audacity 1.3.11. Live Headphone Delay (not playback delay) and Duration of Show issues are burned into the computer and sound card and are not adjustable.
So if you sung the words in perfect sync and the result was perfect at the front and wrong at the end, that's most probably the sound card.
If it annoys you that your own live voice comes back to you late, that's probably just life. Audacity has preferences for Hardware Playthrough (good) and Software Playthrough (bad). Many computers do not support Hardware -- Macs for instance -- and Software is always late.
Not all computers can be changed into Digital Audio Workstations.
Jim Robbins
Post by Jim Robbins » Thu Mar 25, 2010 4:18 pm
Hey Koz -- thanks. I went through the steps for Latency correction exactly as the tutorial suggested, (even checking my steps), but the latency correction didn't happen. When I applied it, nothing changed. Any ideas?
Post by kozikowski » Thu Mar 25, 2010 5:30 pm
Latency correction is only possible in the 1.3 versions of Audacity. I see questions about "The Beta Version" like you may not have it yet. 1.3.11 is the current version of Audacity, no matter that the labels say. Many machines won't run Audacity 1.2 properly -- some not at all.
Try this. Record or find a short piece with clear rhythm. Go into Audacity Preferences and turn off both Software Playthrough and Hardware Playthrough. Leave "Play tracks while recording new ones on." Restart Audacity.
Now play the existing rhythm track while you tap a pencil or other rhythm noise in time to the music and record it. You will not hear yourself tapping. It will sound a little weird. Save that work. Test1
Close the Project and start a new one. Go into preferences and change the second latency number 200 points different from where it is now. Either direction. Restart Audacity.
Play the rhythm track again and again record pencil tapping or other rhythm sound to the music. Stop and save. Test2
Now play both shows back. The matchup between the pencil and the music should be very different between the two performances. Are they?
Did you get weird echoes while you were recording the pencil taps?
Jim Robbins
Post by Jim Robbins » Fri Mar 26, 2010 7:37 pm
Hey Koz -- thanks for the tips. I ended up having to manually adjust (with the time-shift) tool the keyboard track to sync up with the others. I finally got the latency to start changing -- using really big numbers. Something still seems funky. I'll have to keep playing with it.
Post by steve » Fri Mar 26, 2010 11:13 pm
This is going to be easier if we keep it in one topic.
Since this is a different subject to the original title for this topic, let's move it to the new topic here: http://forum.audacityteam.org/viewtopic ... 26&t=27913
