Info in Export Multiple
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Norm Mast
Post by Norm Mast » Mon Mar 15, 2010 4:33 pm
In the past I have been able to Export Multiple and have each track appear with a number in front of the track name I gave it . Short of mannually typing each track with a number in front of it, what do I need to do to get this function back?
Irish
Forum Crew
Re: Info in Export Multiple
Post by Irish » Mon Mar 15, 2010 10:34 pm
Assuming you are exporting based on a label track, give your labels the names "01 <track-name 1>", "02 <track-name 2>" etc.
Then when you select Export Multiple, Tick the box that says "Name files using label/track names".
See this page from the manual;
http://manual.audacityteam.org/index.ph ... t_Multiple
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
waxcylinder
Post by waxcylinder » Tue Mar 16, 2010 10:23 am
In 1.3 (I'm currently using 1.3.12 can't vouch for earlier versions art the moment) in the Export Multiple dialog box there is a box with selectable radio buttons called "Name files" the second one down says "Numbering before Label/Track Name" - check that one.
But personally I'm with Irish on this one - I type the track numbers 01 02 etc into my labels. This is because I tend to record and process one side of an LP at a time - so when I work on side 2 I don't want numbering to stat at 1 all over again.
