I record music digitally with a Zoom R16 and then edit using Audacity.
The music files always sound better if I take the burned CD from Audacity and rerecord it in real time in analog
(to something like a minidisc or reel to reel recorder) and then make a CD from that. This analog version of the
music is much nicer to listen to. I would love to see a plugin effect that could accomplish this "analogization" and save me the
extra rerecording work. Any ideas?
Warming up digital tracks
Re: Warming up digital tracks
interestingjmoore wrote:I record music digitally with a Zoom R16 and then edit using Audacity.
why not use the reel to reel initially
and save two steps
analog is always better:)
are you sure you are not clipping ?
do you have all the useless processing f/x turned off in the r16?
are you recording through their built in microphones ?
MiniDisk is a digital recorder and should not do that.
Pull down Piano2 and Left-Right from here...
http://www.kozco.com/tech/soundtests.html
Send them through your "warming up" pathway and let us know when you get done. Export the new work as WAV. DO NOT go through MP3.
