Attenuating the sound level
Katelynn7
Post by Katelynn7 » Fri Mar 12, 2010 4:24 pm
I have a wav file (Voice only) where I pieced together several audio clips from other files. Some of the clips are louder than others, and I was wondering if there is a way to make the sound level the same throughout the entire file? Thanks. :P
whomper
Probationer
Re: Attenuating the sound level
Post by whomper » Fri Mar 12, 2010 5:56 pm
Katelynn7 wrote:I have a wav file (Voice only) where I pieced together several audio clips from other files. Some of the clips are louder than others, and I was wondering if there is a way to make the sound level the same throughout the entire file? Thanks. :P
normalise each one separately
then paste them together
may need to also compress them separately
if they have different dynamics too not just levels
Post by kozikowski » Fri Mar 12, 2010 10:12 pm
<<<I was wondering if there is a way to make the sound level the same throughout the entire file? Thanks.>>>
He's right. Preparing your individual voice and sound tracks ahead of time is a big deal. It always sounds funny when you produce a whole show with bouncing levels and volumes and try to fix it later.
Sometimes you can use Chris's Compressor to level out the differences, but don't be shocked if the split and shift points sound a little weird.
Chris's Compressor
http://pdf23ds.net/software/dynamic-compressor/
whomper
Probationer
Post by whomper » Fri Mar 12, 2010 10:44 pm
kozikowski wrote:<<<I was wondering if there is a way to make the sound level the same throughout the entire file? Thanks.>>>
Chris's Compressor
that being said
i did have to fix a recording that was given to me
had to look at the tracks from 10000 feet level
see which parts were lower
which was the content - the applause was 10-15 db higher
select them separately
and then raise them enough to match the others
final step - normalise everything
Katelynn7
Post by Katelynn7 » Sat Mar 13, 2010 1:39 am
Thanks guys! :P
Post by kozikowski » Sat Mar 13, 2010 2:40 am
<<<>select them separately >>>
How?
