That's right - about 10MB per minute.Larbo wrote:I just recorded 5 minutes and exported that as a WAV... 50Mb! If it is a fair test... that would exptrapolate to 600Mb for 1 hour!
The dithering settings are to do with converting from one format to another - this only affects "quality vs. speed" of the conversion. It has no effect on the final file size.Larbo wrote:What about those other settings in the WAV Quality window like dithering settings and rate converters?
The "Sample Rate" is how many samples per second are used to represent an analogue waveform digitally - the more samples per second, the larger the file size will be, but the finer the representation of frequency will be, thus allowing higher frequencies to be recorded.
The "Sample format" is another term for "bit depth" and is the number of bits (binary digits) that are used for each sample - the greater the number of bits, the bigger the file size, but the greater the amplitude resolution, thus allowing a greater dynamic range (SNR).
CD's use 44.1 kHz and 16 bit - which is considered to be good enough for home listening. Professional audio is always done with higher sample rates and more bits per sample (for example 48 kHz, 24 bit is very common), but if the recording ends up on a CD, it must be "downsampled to 44.1 / 16 as that is the only valid format for a regular audio CD.
A more complete explanation of digital audio can be found here: http://en.wikipedia.org/wiki/Digital_audio
