Crackling Noise Overdubs; Realtek/Windows Twilight Zone
waxcylinder
Re: Crackling Noise Overdubs; Realtek/Windows Twilight Zone
Post by waxcylinder » Thu Mar 04, 2010 9:46 am
whomper wrote:is the wiki the same as the docs ?
A very good question whomper ...
Yes-ish and no-ish.
The Wiki http://wiki.audacityteam.org/index.php? ... _Home_Page is a repository of useful information (hints,tips, tutorials etc.) It is a an open to edit Wiki - anyone can get an account to edit it and add articles - it is fairly carefully moderated though to avoid misleading and incorrect articles - and to remove spam and abuse.
The Manual that is under development for 1.3/2.0 http://manual.audacityteam.org/index.ph ... =Main_Page is implemented using Wiki technology. Anyone can read it - but it is closed to a specific group of editors who are the only ones who have write access - this is so that we can have greater control over the content and layout of the manual. Note that the manual also contains tutorials for key topics - they tend to be migrated from the Wiki to the Manual as they reach maturity.
Inevitably there are replications of stuff in the manual and in the Wiki - though we work to minimize that as far as possible.
The Wiki deals with 1.2 and 1.3 functionality whereas the manual focuses on the 1.3/2.0 functionality.
The 1.2 manual documentation http://audacityteam.org/onlinehelp-1.2/contents.htm actually lives as part of the Audacity main site with very restricted authorship/editing access.
The editors do ponder from time to time whether there should really be a single entity - to make things less confusing - but then we would need to store and make available archive copies for each release - so don't hold your breath :)
whomper
Probationer
Post by whomper » Thu Mar 04, 2010 3:49 pm
as a mere user
I would like the manual to tell me all about the features
in release x.y.z. and maybe how to set up things. but not solve every oddball problem.
i would like the wiki to tell me everything about all releases of audacity as well as pc tips and fixes, and also general recording info, pointers to other stuff, and anything that is useful.
default device
Post by default device » Mon Mar 08, 2010 5:04 pm
[quote="stevethefiddle"][quote="default device"]I have the computer connected as "Tape 2", i.e. computer output to amp "Tape 2 Input" and amp "Tape 2 Output" to computer "line in".[/quote]
Ah, now there is a possible problem/confusion there - it depends on what signal routing goes on in the amplifier. Do we know for sure if the amplifier routes the Tape2 input to the Tape2 output?[/quote]
I assume so, since if I connect the computer's line out to the amp's line in, and set the computer to use it's line out, then it goes to amp and no where else, because that's what "use the line out" means, in English. If . . .
1. the computer were sending the signal somewhere else *in addition* and
2. It wasn't designed by idiots
. . . it would say so, and allow me to control that as well, and it doesn't, so it isn't.
The amp, in the meantime, allows me to switch between source monitor and playback monitor. Source is any source *but* "tape in". "Playback" makes "tape in" the source. Therefore, I set it to playback and it "plays" i.e. sends to the computer that which the computer sent to the amp. When it arrives back at the computer, the computer then does its thing, which is the problem area.
[quote="stevethefiddle"][quote="default device"]There's a line out from the computer to the amp and a line out from the amp to the computer. If "line in" on
the computer really meant "line in" the computer would be recording a signal that left the computer and returned,[/quote]
Only if the Tape2 input on the amp goes to the Tape2 output. On my amp it doesn't. [/quote]
I don't see how that's possible. That's the point, to route the source to the recorder. "Tape IN" means that which you want to go to that recorder.
[quote="stevethefiddle"]If I set on my amplifier the "Recording Source" as Tape2 and the "Playback Source" as Tape2, then:
"Tape2 Out" sends signals from the pre-amp section to the outside world and
"Tape2 In" takes signals from the outside world and plays them through the power amp section,
but "Tape2 In" is isolated from "Tape 2 out".[/quote]
Again, I don't get it. If you set the recording source as tape2, and tape2's input comes from the computer, then tape2's output is the computer's output.
It goes back to the computer or anywhere you lead the cables to.
[quote="stevethefiddle"][quote="default device"]Let's see, what are we doing? Playing a file from the computer while recording. Whose idea was it to add the
playing file as an input to the recording? Why? Where is it being added and how? Why can't you just turn it off? What is the logical connection between them?
Why would I ever want them to be mixed any way, shape or form? Under any circumstances, for any purpose?[/quote]
Let's split these questions -
[u]"How" can it happen[/u] that a file that is playing is added to the recording mix?
1) If you are recording from "Stereo Mix", then that's what "Stereo Mix" does - it "mixes" ALL sounds that are playing on the computer and sets that mix
(which is in stereo) as the recording source.[/quote]
But only one sound is being *played.* The other is being *recorded.* The *information* must remain separate or you couldn't record discrete tracks. I'm
guessing what happens is that *the capacity of the digital/analog converter* is being exceeded. It has to convert to play, *and* it has to convert to record,
simultaneously. I don't see that as being the same as clipping, but what do I know. Bottom line, there's no direct control over recording levels. You have
to guess what *all* the tracks are going to add up to, then subtract a dB or three for headroom. IOW you're setting record levels so as to not exceed the
total capacity of the converter, part of which must be dedicated to playback and is therefore unavailable for recording. The simple solution would be to
have separate converters for playback and recording. Separately controllable, of course. That's the point.
[quote="stevethefiddle"]2) If there is a "loop-back" from the Line out to the Line input on the computer, then the sound that is playing will be recorded,
just like using "Stereo Mix". An example of this would be if you connect the "Line out" from your computer and connect it to "Tape2 In" on the amp, and
connect the "Pre-amp out" of the amplifier to the "Line In" on the computer. Everything that is playing will be recorded.[/quote]
You mean every time I record an overdub, the original track is re-recorded?
[quote="stevethefiddle"][b]"Why" would you ever want it to happen[/b]?
1) You want to record something that is playing on Internet radio - how are you going to do it? You need to record "the sounds that are playing on your
computer". That's what "Stereo Mix" does (or a loopback connector)
2) You wanty to record a "software synthesizer" - how are you going to do it? Again you need to record sounds that are playing on your computer.
3) You want to record a midi track that is playing on the computer and your sound card is using a software synth. - exactly the same as above.
Am I making sense?[/quote]
Not to me, I'm afraid! But I really appreciate your efforts, I must say.
-- ps sorry for the editing but at present I can't see what I'm typing . The "post a reply" window won't scroll past a certain point . Every new letter, tnhe screen jerks down to the end of the reply and then jerks back to the middle of the reply. Is this a test of some sort?
waxcylinder
Post by waxcylinder » Mon Mar 08, 2010 5:23 pm
default device wrote:ps sorry for the editing but at present I can't see what I'm typing . The "post a reply" window won't scroll past a certain point . Every new letter, tnhe screen jerks down to the end of the reply and then jerks back to the middle of the reply. Is this a test of some sort?
No it's a "feature" - I get this annoying behaviour too when I type long responses - so my normal workaround is to the the post creation in Word and then paste it in.
Post by steve » Mon Mar 08, 2010 6:45 pm
(Reposted previous message because the formatting has gone weird in the original post - appears to be a glitch in the forum software)
stevethefiddle wrote:
default device wrote:I have the computer connected as "Tape 2", i.e. computer output to amp "Tape 2 Input" and amp "Tape 2 Output" to computer "line in".
default device wrote:There's a line out from the computer to the amp and a line out from the amp to the computer. If "line in" on
stevethefiddle wrote:If I set on my amplifier the "Recording Source" as Tape2 and the "Playback Source" as Tape2, then:
default device wrote:Let's see, what are we doing? Playing a file from the computer while recording. Whose idea was it to add the
"How" can it happen that a file that is playing is added to the recording mix?
stevethefiddle wrote:2) If there is a "loop-back" from the Line out to the Line input on the computer, then the sound that is playing will be recorded,
stevethefiddle wrote:"Why" would you ever want it to happen?
Am I making sense?
Post by steve » Mon Mar 08, 2010 7:01 pm
stevethefiddle wrote:I assume so, since if I connect the computer's line out to the amp's line in, and set the computer to use it's line out, then it goes to amp and no where else, because that's what "use the line out" means, in English. If . . .
Your logic makes perfect sense but you're not allowing for Microsoft.:D
It's the "Stereo Mix" feature that is causing the confusion.
On SoundBlaster sound cards, "Stereo Mix" is called "What U Hear", and apart from the appalling spelling this description of the feature may be a bit more clear.
1) As you accurately described; when you set the computer to use it's line out, the computer plays through the line output and only through the line output and that is what you hear.
2) When you set the computer to record from "Stereo Mix", the computer takes its recording input from the sound card output. It will record "what you hear" - and since you have set the computer to play through the "Line out", the computer will now record the line out of the sound card.
Post by steve » Mon Mar 08, 2010 8:27 pm
This is what I mean:
On my amplifier the "Tape In" on the Amplifier does not go back to the "Tape Out" on the Amplifier.
The output from the recording device goes into the amplifier but does not go back to the recording device, it just goes out to the speakers.
whomper
Probationer
Post by whomper » Thu Mar 11, 2010 5:34 pm
whomper wrote: all the more reason to use word
automatically create an index
There is an index for the wiki. It's at http://wiki.audacityteam.org
There's also a list of "All Pages" http://wiki.audacityteam.org/wiki/Special:Allpages
thanks
is there anything like that for the docs too ?
Post by steve » Thu Mar 11, 2010 5:53 pm
There is an overview of all the main documentation here: http://audacityteam.org/help/documentation
The "Contents" of the 1.3 manual is on the front page of the manual: http://manual.audacityteam.org/index.ph ... =Main_Page
The Index for the manual is here: http://manual.audacityteam.org/index.php?title=Index
There is also a list of Frequently Asked Questions (FAQ) here: http://audacityteam.org/help/faq
waxcylinder
Post by waxcylinder » Thu Mar 11, 2010 5:54 pm
