copying waveform graphic
shinnen
Operating System: Windows XP
Post by shinnen » Sun Jan 20, 2008 4:07 pm
Hi,
Is there a simple way, or program, that will allow me to copy the wave form to a graphics (jpg) file?
.... john
straightupwv
Re: copying waveform graphic
Post by straightupwv » Mon Jan 21, 2008 3:41 am
You can capture what's on the screen by doing a screen shot. Open the wave form you want the image of in Audacity and hit the "Print Screen" key on your keyboard. Open a graphics program and select "edit/paste". Then save the image as "whatever_you_want_to_call_it.jpg"
Time flies like an arrow. Fruit flies like bananas.
shinnen
Post by shinnen » Mon Jan 21, 2008 9:06 pm
Thanks Straightupwv,
I was aware of that method. I don't why, but I was thinking that Audacity might have the capacity to copy the wave.
...... john
alatham
Post by alatham » Mon Jan 21, 2008 11:01 pm
shinnen,
If you're thinking of taking a screen shot of a waveform and converting that to an audio file, it can't work unless you've only got a few hundred samples in the waveform. Even then, you'll have trouble finding software to do that.
For the average file, a single pixel's worth of display might represent hundreds or thousands of samples. There's no way one pixel can represent all that data.
shinnen
Post by shinnen » Tue Jan 22, 2008 12:06 am
Hi Alatham,
No, I'm only interested in capturing it form the artistic point of view. It seems like a potent visual representation of emotions, so I'm looking at it from that perspective.
........ john
alatham
Post by alatham » Thu Jan 24, 2008 8:57 pm
Ahhh, Audacity doesn't do that itself.
I would use straightupwv's advice and use the 'print screen' button. But first I would press [ctrl]+[shift]+f to expand all the tracks to fit the entire Audacity Window. That's the highest resolution picture you'll get out of Audacity.
shinnen
Post by shinnen » Thu Jan 24, 2008 9:56 pm
Thank you both. I'll try that....... john
