Windows 7, cant get devices right
drumon
Post by drumon » Fri Feb 19, 2010 5:50 pm
I'm trying to record LPs from my hifi.
I am using a headphone out into my laptop line-in socket.
I have different options for sound devices, eg. interface host is "MME host" or "Windows Directsound host"
Then "Microsoft Soundmapper" input or output vs. "Speakers/Headphone IDT" or "Microphone/line-in IDT"
What do I choose to make it work...?
When I press record a message pops up saying the input couldnt be used because the settings are wrong????
Not sure what to do next.
I have everything set at 44100Hz and 16bit recording quality.
What does happen if it does work, is the recording plays back through the speakers and sometimes I cant seem to UNselect the built in laptop mic either which is a nuisance.
Re: Windows 7, cant get devices right
Post by steve » Fri Feb 19, 2010 10:57 pm
Set the "Line In" as the default recording input in the Windows Control Panel http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
drumon
Post by drumon » Sat Feb 20, 2010 10:38 am
stevethefiddle wrote:Set the "Line In" as the default recording input in the Windows Control Panel http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
Thanks for the link. I'll try it all out and report back.
drumon
Post by drumon » Sat Feb 20, 2010 11:07 am
I have tried everything in the above link to try and select the correct input.
Now, I get this message when trying to record :
"ERROR WHILE OPENING SOUND DEVICE, PLEASE CHECK THE INPUT DEVICE SETTINGS AND THE PROJECT SAMPLE RATE"
I have checked all sample rate settings in windows and audacity, they match, 44100Hz 16Bit.
In the Audacity screen, there are pull down menus to choose input and output.
I have choices between the following,
MME Sound Mapper input
MME Mic/Line in
Windows Direct Sound mic/line in
What one should I be choosing? I am recording on a dell laptop, with no external soundcard.
What else am I doing wrong?
drumon
Post by drumon » Sat Feb 20, 2010 11:04 pm
UPDATE:
It now seems to be working fine.... Dont know what I had set differently this time, but there you go :?
Great software.
