I am recording (ver 1.3.x) voice and have setup the configuration (Preferences / Recording / Channel) as MONO
Also the Audio Track is set to show MONO
Issue
* When I record, the voice shows in one Channel - but its divided into two (see attached file)
* I am not sure what is wrong
Thanks alot for any advise
Frank
Mono Recording showing as In Left Channel while recording
frankturley
- Attachments
- Mono-Error.png (27.1 KiB) Viewed 395 times
Re: Mono Recording showing as In Left Channel while recordin
That is a problem, but it's not one channel of a stereo pair. It is a mono track, but the signal is shifted vertically (by a long way). This is called "DC Off-set" and that is an extremely bad case of DC Off-set. The problem is usually (but not always) caused by a faulty sound card.
Tell us about your set-up (we can't see it) and what you are doing. Too much information is better than not enough.
