audacity crash on importing audio file
Just updated AudioDesk 2.1 (MOTU) to 2.11 for use with OSX 10.5.1 Audacity 1.2.5 imported sound designer II files from AudioDesk 2.1 with no problem (in a previous version of osx). Now Audacity crashes when I try to import sdII files from AudioDesk 2.11 Hyperengine-AV imports all the audio files from 2.11 with no problem. I deleted the Audacity preferences file which didn't help. Any suggestions?
Re: audacity crash on importing audio file
The upgrade to Vista and Leopard caused a number of problems. Audacity 1.4.x is really close to release.
