no option to choose usb audio codec
This section is now closed
guagua
Post by guagua » Sat Jan 12, 2008 7:43 pm
i recently was given an ion usb turntable. i am running mac os 10.1.4 and installed the audacity software. in the preferences menu, there is no option to choose usb audio codec as per the instructions. there is only the possibility to choose built in audio. i have tried recording using this option, and it records everything - ambient noise, etc. like recording a record from a handheld mic...
can anyone help me with this? thanks very much in advance.
paul
Re: no option to choose usb audio codec
Post by kozikowski » Sat Jan 12, 2008 11:22 pm
<<<it records everything - ambient noise, etc. like recording a record from a handheld mic...>>>
That's because it is recording from a hand-held mic--the one inside your PowerBook.
DId you get this turntable because someone thought about you over Christmas, or someone else got it over Christmas and couldn't get it to work?
If it didn't immediately show up in the Mac preferences, try restarting the Mac with the turntable connected and running (not playing). If it still doesn't want to work, change USB connections and restart again.
skybolt
Post by skybolt » Sat Apr 19, 2008 12:43 pm
O.K., I know I am resurrecting an old post, but it found it during a search. I have the same problem as the original poster and tried restarting, etc as instructed, but that did not work. I downloaded the newest version of Audacity (1.3.3) but same results. Any other ideas? Running 10.5.2. Thanks in advance for any help!
Mary
waxcylinder
Post by waxcylinder » Sat Apr 19, 2008 2:38 pm
Mary - see my response to you in the 1.3 forum http://audacityteam.org/forum/viewtopic.php?f=17&t=4069
and please don't double post.
