Export Multiple MP3 problems
Hey, I have a problem. I'm ripping my vinyls to my hard drive using my line-in, and recording them with audacity. This works just fine. However, when I use labels to separate the tracks and try exporting them as MP3s, the audio overlaps for some reason, causing the last 5 or so seconds of each track to be the beginning of the next one. Any help or solutions? Thanks!
Re: Export Multiple MP3 problems
This is a known bug in Audacity Version 1.3.10.
It is fixed in 1.3.11, which you can get from here:
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
We hope you're using Audacity 1.3.10 and you just posted in the Audacity 1.2 forum by accident. But, yes this is a known problem in 1.3.10.
Yeah, I guess I posted in the wrong forum, oops.
But anyway, yay! I'm glad it's just a bug, and that it's been fixed. Thanks a lot, guys!
