in other words the level I get analogic with the MIC IN and the level I get digital via firewire are not comparable?
but actually if I push the mixer slide up to 0 dB (with firewire connection), still I have not the same level as with MIC IN connection, and in order to have the same level I have to increase LEVEL and GAIN on the mixer with resulting higher ground noise ...
anyway I will try further.
regardins multiple tracks recording, I already did what you suggest, but I do not understand how to assign each audacity track to each channel.
moreover when I try to record, I get the message"Error at device opening. check device input setting and sample frequency" (this is a translation of what i get in italian).
maybe I have to enable somewhere the multipletrack recording or the channel assigning.
thanx for your attention
Alex
