Audacity/Audio MIDI problem
This section is now closed
adegg
Post by adegg » Wed Jan 02, 2008 9:01 pm
I am trying to set-up my ion USB turntable and have run into an Audacity/Audio MIDI problem. I have an iMac Intel and followed the instructions that came with my turntable concerning Intel-based Macs, i.e. I downloaded a version of Audacity from the website. The version I downloaded was 1.2.5 as this was marked for Intel. Having downloaded it, I followed the instructions in the software installation booklet. In 'Properties For' in the Audio MIDI setup, I changed the setting to USB Audio CODEC. However, in Audio Input it told me that 'Input is not supported', so I couldn't set the sample rate or format. I managed to get Audio Input to appear by changing to 'Built-in Line Input' in the 'Properties For' setting but now all options for 'USB Audio CODEC' in the pull-down windows - in 'Properties For' and the 'Default/System Output' windows - have disappeared. I have Restarted my Mac and started over from scratch, including unplugging/replugging the USB cable, but to no avail. 'USB Audio CODEC' has simply vanished. I will greatly appreciate any suggestions, as I have a very long queue of vinyl memories waiting to enter the 21st century.
Re: Audacity/Audio MIDI problem
Post by kozikowski » Wed Jan 02, 2008 9:09 pm
You may need to stay in the 20th century to get this to work. Does your turntable have the two analog RCA cables as well as the USB? If so, I would recommend transferring all the work analog. Once you have troubles with USB software, you could be there a very long time struggling--and even if you succeed, not all the records will transfer.
I wrote a How-To:
http://audacityteam.org/forum/viewtopic ... 8840#p8840
If your turntable has no Line/Phono switch, then it's a little more complicated. If it has no RCA cables, then this could be rough.
adegg
Post by adegg » Thu Jan 03, 2008 2:36 am
well, i don't know whether to laugh or cry. I knew I should've stayed in the 20th century. There are indeed two analog RCA cables sticking out the back of my deck. I shall study your analogue copying method from your other post and attempt to emulate. No Radio Shack at hand over here in London (I don't think), but as long as those cables are standard kit, I should be able to find some. Ta
Post by kozikowski » Thu Jan 03, 2008 8:00 am
Ideally, you'd turn up a stereo audio cable, female RCA to male 3.5mm. That will connect without the coupler/barrels. The cable with the male RCAs is more common.
waxcylinder
Post by waxcylinder » Thu Jan 03, 2008 9:44 am
adegg wrote: No Radio Shack at hand over here in London (I don't think), but as long as those cables are standard kit, I should be able to find some.
Thee's lucky lad - a quick trip up t'Tottenham Court Road should easily enable you to source the required component (harder to do in Manchester ....)
adegg
Post by adegg » Thu Jan 03, 2008 6:40 pm
Tott Rd it shall be. As a Manc abroad, I always appreciate words of wisdom from the old homeland..
Post by kozikowski » Thu Jan 03, 2008 6:50 pm
Especially handy since Waxy and I run on an 8 hour time difference.
