No Stereo!
wilen
No Stereo!
Post by wilen » Sat Jan 30, 2010 12:41 pm
I use a USB plug in adaptor for inputting audio into my laptop and recording on to Audacity. Everything`s fine with one exception - it only records in mono. I`ve checked the `mic` input on the adaptor - it`s wired for stereo OK. Audacity is set to `New Stereo Track`. In preferences, it`s set to 2 stereo channels, recording device - USB input. I`ve tried the above on my mini notebook, but with the same result. I really need to record in stereo. Any ideas please? Thanks.
(for the record, I`ve tried connecting the laptop`s headphone out to the mic in, and played some audio on the PC. This records in stereo ok, but with relatively poor sound quality).
Re: No Stereo!
Post by steve » Sat Jan 30, 2010 2:10 pm
wilen wrote:it only records in mono
That's normal for recording from one microphone. Most microphones are mono.
wilen
Re: No Stereo!
Post by wilen » Sat Jan 30, 2010 2:26 pm
But I`m not recording with mic`s - I`m going line in from external device, via USB port with the sound card/adaptor.
Re: No Stereo!
Post by steve » Sat Jan 30, 2010 4:06 pm
wilen wrote:But I`m not recording with mic`s
wilen wrote:I`ve checked the `mic` input on the adaptor
wilen
Re: No Stereo!
Post by wilen » Sat Jan 30, 2010 11:21 pm
I take your point, stevethefiddle, but I said `mic`, as the input on the USB adaptor is marked with a mic icon. However, as I stated, I`ve had the cover off the gadget and there`s no doubt that the input socket is wired for stereo. As I`m inputting with a stereo signal thro a stereo lead, shouldn`t I be getting a stereo signal into Audacity??
Re: No Stereo!
Post by kozikowski » Sun Jan 31, 2010 11:25 am
Mono microphone sockets have two connections, but they're not both sound.
(scroll down)
http://www.kozco.com/tech/audioconnecto ... ctors.html
wilen
Re: No Stereo!
Post by wilen » Sun Jan 31, 2010 8:18 pm
This socket has 3 connections - it is wired at the 3 points where the connecting points of the stereo jack make contact - namely, tip, ring and sleeve. If it were mono, it would only have tip and sleeve contact points. There`s no doubt that it`s wired for stereo. I think the problem I`ve got is within the laptop, somewhere between the USB in port and Audacity??
Irish
Forum Crew
Re: No Stereo!
Post by Irish » Sun Jan 31, 2010 11:49 pm
What's the make and model number of your USB adaptor/sound card?
Do you have the spec. or instruction manual for it, and does it definitely say it has a stereo input?
Most USB sound cards use RCA sockets, not 1/8" jacks for stereo inputs, and the fact that it says mic-in suggests that it is, in fact, mono. If you look at the second picture in Koz's link above, you will see that the ring connection provides power for the microphone, and not a second input channel.
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Re: No Stereo!
Post by steve » Mon Feb 01, 2010 12:01 am
In addition to the post from Irish, where is the stereo input source coming from? (what's plugged into the USB device?)
wilen
Re: No Stereo!
Post by wilen » Mon Feb 01, 2010 10:12 am
Thanks, again, irish and stevethefiddle. I don`t still have the info on the USB adaptor. It`s fairly bog standard, and your comments re koz`s 2nd diagram may well apply, although it was supposedly for stereo transfer. I`d be happy to invest in another, but how can I define whether one is stereo or not? All the ones I`ve seen seem to have the `mic` icon over the input port. Your help is much appreciated.
(The stereo input source is from CD player, stereo cassette player, etc.).
