I am working with e-learning projects, where each lesson contains about a hundred audio tracks (for slides, objects and such). Audacity is unbeatable in removing all the noise from recordings with amateur equipment, truly a great product. What concerns me from the usability point of view, is the inability to save the edited tracked over the original .wav file, thus overwriting it. I end up with a voluminous filing system (slide1.wav, slide1a.wav, slide1b.wav, etc). Instead, I would like to save very much in a fashion most users are accustomed to: opening, editing and saving using a single file (wav).
Naturally, this is more of a suggestion to developers, than an actual problem. Nevertheless, maybe someone can offer an optimization to this kind of workflow? I am sure there are other users with WAV editing needs
I am terribly sorry if this issue has been discussed ad infinitum - haven't found anything in this regard.
Sincerely yours,
MK
P.S. Happy New Year, too!
