Loud Static with External Microphone
Retconaddict
Post by Retconaddict » Sat Jan 23, 2010 10:54 pm
Hi, I bought a Rode NTG-2 microphone the other day. It has an XLR connection, so I have had to use an XLR to mini jack (3.5mm) to make it fit into my laptops external mic port.
My trouble is that whenever I try recording something there is a very loud hissing sound, almost like static. This is on the beta 1.3 version. On the stable audacity (1.2.6) the static is at a lower level, but it still drowns out whatever I'm trying to record. Using a noise removal is not helping, as it removed the hiss but makes the sound very muddy and distorted (this is on both versions).
I'm wondering - is this a problem with my microphone, my cable, or a setting in Audacity?
Thank you,
Rian
Re: Loud Static with External Microphone
Post by steve » Sun Jan 24, 2010 2:25 am
Retconaddict wrote:is this a problem with my microphone, my cable, or a setting in Audacity?
Probably none of those. The hiss is probably from the sound card. If you are using the microphone input on a laptop PC they are notorious for really bad sound.
Post by kozikowski » Sun Jan 24, 2010 4:16 am
Does the adapter look like this...?
http://kozco.com/tech/audacity/UnbalBalAdapter.jpg
If the 3.5mm plug has one more tiny metal ring than that, then it's not a proper adapter. Neither of these would work...
http://www.kozco.com/tech/audioconnecto ... ctors.html
Retconaddict
Post by Retconaddict » Sun Jan 24, 2010 12:45 pm
Ah, my "adaptor" has two rings.
Any idea where I could find that sort of adaptor, with only one ring? I checked on Amazon and all of the pictures of the items had two rings.
Post by steve » Sun Jan 24, 2010 1:02 pm
Retconaddict
Post by Retconaddict » Mon Feb 01, 2010 1:49 pm
Ah. Turns out it was indeed the cable - it was broken. Bought a new one off of Amazon, works fine.
Thanks for your help.
