Bug when importing audi from a video file
I try to import audio by drag and drop to the audacity window, but sound appears much shorter and corrupt. Audio compression is in LAME mp3 192 kpb CBR. How solve?
Re: Bug when importing audi from a video file
Audacity doesn't know how to deal with a video file. Separate the sound portions into their own file and then open that.
To import audio from a video file, you first need to have Version 1.3 of Audacity.
The current Beta version, 1.3.11 is available here:
You will also need to install the ffmpeg library which you can get from here:
http://manual.audacityteam.org/index.ph ... tallffmpeg
Once you have ffmpeg installed, Audacity (version 1.3) will import the audio from many video file formats, as well as increasing the range of audio formats which it will recognise, including WMA.
PO'L
PO'L
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
Thanks, it works
