bounce to disc
This section is now closed
barnaby
bounce to disc
Post by barnaby » Fri Dec 28, 2007 4:51 am
I'm sure I"d figure this out, but sinc eyou're here -- to create a stereo mix of several tracks -- where is the option for this?
thanks, Barnaby
Re: bounce to disc
Post by steve » Fri Dec 28, 2007 4:01 pm
Pan the tracks to where you want them in the stereo mix, then select the tracks to mix and click on: "Project -> Qick Mix".
Note 1) If your project preferences are set for mono and all tracks are set panned to center, you will get a mono mix from doing this. To force a stereo mix, insert an empty stereo track into the project and include it in your mix.
Note 2) When you "Export" the audio, this will automatically mix down tracks anyway, so if you have the export format set to stereo, then you will get a 2-track (stereo) mix.
barnaby
Re: bounce to disc
Post by barnaby » Sat Dec 29, 2007 4:33 am
thanks -- worked great. got it as a wav file into itunes and I can burn a disc.
