Downloading LAME plugin
This section is now closed
RonFig
Post by RonFig » Thu Dec 27, 2007 11:27 pm
What am I doing wrong--I have followed the direction for downloading the LAME plug in for the Mac so I can export as a MP3 file...when I try to export, it looks for the plug in and the plug in is grayed out. It is not a .sit file--I have deleted and downloaded again. And I have followed the directions exactly so I just don't know what to do. I want to be able to record and move the recordings to iTunes. I am running Leopard on an iMac.
I am running Audacity 1.2.5-pre (what does the 'pre' mean)
I have read everything in the previous thread. I have tried to put the libmp3lame.dylip file in to the applications-audacity but it wont allow me to do that.
Any help is appreciated.
Re: Downloading LAME plugin
Post by kozikowski » Fri Dec 28, 2007 12:06 am
Almost enough information.
If you select Apple > About this Mac, What does the Processor entry say?
jay
Post by jay » Wed Jan 02, 2008 8:37 pm
I'm sure Koz will give you a full answer, but I've had the same problem, and my workround is to export the tracks as WAV files, which doesn't need an extra plugin, and then to get iTunes to convert them to AAC (the standard iTunes format) by selecting the track, and going to the ADVANCED menu. You can also set the track to export as AIFF from the Audacity FILE menu, which iTunes reads, and can also convert to AAC.
Hope this helps.
Jay
Post by kozikowski » Wed Jan 02, 2008 8:59 pm
<<<I'm sure Koz will give you a full answer>>>
No. We're goin' with yours.
Oddly enough, we had a poster who changed preferences to AIFF and had trouble getting into iTunes that way. He followed my instructions to put Audacity back to Windows WAV PCM export and it worked perfectly.
No, I don't understand, either.
