Hi
I have the newest version of Audacity installed (1.3.9 unicode,) and when I try to record something and store it as a WAV, the file-export sequence leads me to a window called something like "edit metadata."
I searched this site for help,also looked into the "help" section of Audacity, but cant figure out how to make the program record/save things WAV format.
Thanks in advance for your time
record as WAV ?
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: record as WAV ?
Just click through it.
Or you can turn the metadata editof off with a setting in Preferences (sorry I can't look exactly where right now as I'm currently capturing FM off-air).
Re: record as WAV ?
Edit menu > Preferences > Import/Export tabwaxcylinder wrote:you can turn the metadata editof off with a setting in Preferences
BTW, I've moved this topic from the Audacity 1.2 part of the forum to the 1.3 part of the forum.
Re: record as WAV ?
All is OK now - thanks for help
