Why Do EQ Adjustmenst Not Work?
KenRyan
Post by KenRyan » Wed Jan 20, 2010 5:38 pm
Does the EQ effect in Audactiy only affect the entire track? I tried applying EQ to a certain selection of my audio, then clicking "OK," but the wave form remains unchanged(?). If I use the FFT Filter, I CAN change just a selected area.
Am I missing something? Thanks.
Ken
Re: Why Do EQ Adjustmenst Not Work?
Post by kozikowski » Wed Jan 20, 2010 6:01 pm
Does the selected area sound different? If you make an equalization change that doesn't change the waveform very much, you may not be able to see it -- but you should be able to hear it.
What kinds of changes are you trying to make? You select a portion of your show, open Effect > Equalization, push the blue line around to where you want it and press OK. Did I get any of that wrong? I just did it on a simple sound clip and it worked perfectly.
KenRyan
Post by KenRyan » Wed Jan 20, 2010 6:15 pm
Koz,
Yes I used it as you describe, but I had only a very small (about a 10th of a second) portion selected. As an experiment, I dragged the blue line on the EQ tool as far down as it will go (looks like -24db), and it did not affect the sound or the wave form. Then I tried choosing one of the preset curves on a 10-second section, and it worked as expected, chaning both the waveform and the sound. Perhaps there is a minimum amount of audio needed in the selection?
Thanks,
Ken
KenRyan
Post by KenRyan » Wed Jan 20, 2010 6:20 pm
Koz,
I tried gradually increasing my selection size until I got to half a second (I actually only had about a tenth selected initially). It was only at that point that the EQ affected my audio. So I guess there is a half-second minimum selection?
Ken
Post by steve » Wed Jan 20, 2010 6:45 pm
If you upgrade to Audacity 1.3.11 there is no minimum length limit for the Equalizer.
KenRyan
Post by KenRyan » Wed Jan 20, 2010 6:59 pm
Ahhhh. OK, thanks. That's still in BETA isn't it?
Ken
waxcylinder
Post by waxcylinder » Wed Jan 20, 2010 7:41 pm
Yes, but it's a very mature Beta now - approaching Release Candidate status.
For many modern platforms it's actually more stable than the officially "stable" 1.2.6
Post by kozikowski » Wed Jan 20, 2010 9:54 pm
The last two generations of modern Macs will not run Audacity 1.2.
In that sense, it's perfectly stable.
waxcylinder
Post by waxcylinder » Thu Jan 21, 2010 10:09 am
kozikowski wrote:The last two generations of modern Macs will not run Audacity 1.2.
ROFL :lol:
Yup - just like the broken (analog) watch that's precisely right twice every day ....
